Split-Screen (the variation to PIP)...Though that OTA Scan / OTA = 3 or 4 tuners would be nice too.
I like the Split Screen idea, my older Sony rear projection use to have that, it was FAR better than any other PiP.
I was also going to say: Multiple video outputs hot at the same time: HDMI + Component.
But since I can do Directv2PC, it isn't really that needed. (That is unless it can be done already, please let me know if so).
I don't understand why this is not available. It seems like it would be so easy to implement.autotune on hr receivers
You still need to plug either the DECA or your receiver into an Ethernet port in order to connect to the internet
A)
So I can hook up on one HR24 the following and have them all play the same video at the same time?
1) Component to my HDTV + digital audio
2) HDMI to my computer monitor
3) Composite to my SDTV + red/white RCA stereo audio
I hadn't tried it yet since I was sent an extra receiver, and the Directv2PC worked right off the bat. (Don't mean to hijack the thread with this, but just wanted to check.) I'm guessing the same with audio too
And I also only need one port if I directly plug my DVR into my router as well. So WiFi will allow me to free up a portOf course, but that's only one port needed.
And I am currently doing that. My HAVA box is plugged in via component and my TV is plugged in via HDMIYep, you have that now. All outputs are hot at the same time.
The same can be said for many if the features others would like to have added
Limited time offer
