When it does it again, I'll be sure to take a video, and put it on YouTube or Vimeo. I've always noticed it in the morning and at night. Do they uplink all the local channels in Hastings, or just the Hastings channels?
Here is a very descriptive response I received in another forum.....
"Here's the issue in a nutshell. Dish Network's uplink center for the Lincoln market is at KHAS-TV in Hastings. KLKN's transmitter near Utica does not put out a strong enough signal to always reliably cover Hastings since they moved from channel 31 to channel 8 in 2009. The problem is that the Lincoln market is really two market areas -- Tri-Cities and Lincoln. DISH (and DirecTV, I might add) are actually both based out of the Tri-Cities side of the market, and can easily receive KHAS, KGIN (which is displayed as KOLN), KHNE (which is displayed as KUON), KHGI, and KFXL (via KHGI DT2). As KLKN does not have a Tri-Cities over-the-air feed, but is received over-the-air from the Lincoln area using a powerful antenna at the KHAS facility, bad weather will disrupt the signal.
Alternatives? KLKN needs to turn up the power, or Dish needs to use an uplink facility closer to Lincoln. The latter's not going to happen, so it's going to take a KLKN power increase to fix the issue. They transmit at less than 30,000 watts and require an OTA repeater on channel 31 in Lincoln just to even provide a local-grade indoor signal to their city of license, Lincoln.
KOLN isn't much better but they at least (a) transmit a little closer to Lincoln, from Beaver Crossing, and (b) have KGIN which provides a reliable signal to Dish and DirecTV.
I don't know why Dish doesn't carry KHGI in HD, since it's the ABC affiliate for the western 1/2 of the Lincoln/Tri-Cities market and does broadcast in HD. They probably figure they already have ABC HD covered with KLKN, but as you are experiencing, ever since KLKN moved from 500,000 watts on channel 31 (which covered part of the Omaha area as well) to 25,900 watts on channel 8 (which is hard to get even in Lincoln) that strategy hasn't worked so well."
Time Warner is drooling in anticipation.This will be a significant determining factor for me when my contract with Dish is up because most of our programs we record is an ABC program.
I don't know what a DMA is but in the Lincoln market, there are two local abc channels. Dish broadcasts both in SD, and only one in HD. Directv broadcasts both stations in HD. If dish doesn't want to broadcast both in HD, then I think they should start broadcasting khgi in HD and stop broadcasting klkn in HD.
'Can a Dish CSR on this forum help? Seems like Dish needs to be in contact with KLKN, or something... this shouldn't happen in the first place.
Limited time offer
