OpenBox,Skybox or Traxis DBS6100HD | SatelliteGuys.US
Johnnyfeedback
24
My openbox 10 died but want a HD with S2 to replace it with
Seems that the Openboxs and Skyboxs are mostly Clones
And their Satellite maps and not from the united states but from other countrys?
Just seen a Traxis DBS6100HD for $130
Just want to know more about this receiver and have these also be cloned?
want to make sure when I buy a new receiver that the satellites are from the States
and don't want to download any files to get them.Thanks all........JF
Go contact 50 different companies in China that sell openbox and/or skybox. Each one will tell you they are the factory and have all original, they love you longtime! :D
Traxis is imported by DMS, I don't think you'll see those counterfeited. They should have a list with USA satellites but likely one done by China unless DMS improved on the list.
Thought I would go with a Traxis DBS6100HD
with my 10 foot C/Ku dish
At least there will be no worry about getting Satellites from the states with the Traxis........JF
orbit
Amiko Mini HD, HD SE IR Sensor Clarification
