OPPO BDP-103 Blu-ray Player Review | Page 2 | SatelliteGuys.US
One issue I've been having from time to time (I think it's the player, but I am not positive): the sound would disappear in the middle of the movie. Pausing and re-starting the Blu-ray would usually fix it. Doesn't happen too often, but I had this happen to me more than once.
Ive never had that. Only blu-ray Ive had an issue with was the Total Recall disc, my biggest issue was lip sync and that HDMI In, which was the reason I upgraded. Sharpness +1 is now out, it was like when I tried the darbee, things looks cool at first, but then I noticed some issues that I did not like.
Now that the input is working reliably, Im gonna do one thing I have been wanting to check. Im going to hook the BDT500 Panasonic up to the 103 In, and check 720p and 1080i sent in and 1080p sent out, with the spears and munsil disc. Just wanna check and see if what comes out passes the same tests as what goes in.
103"D" notification is up where you can enter an email address for availability notification. I'm less impressed by it having Darbee on board, but Im pissed if its true they removed the Marvell noise reduction processing that was "undefeatable" on the 103's HDMI 1 out.
Firmware update
New official firmware update BDP10X-70-0218 was released a few days ago:
This release is for the OPPO BDP-103, BDP-105, BDP-103D and BDP-105D Blu-ray Disc players.
Special Notice:
1.Once this firmware version is installed on the player, you will not be able to revert back to any previous official or public beta firmware. There will be no problem upgrading to any future official or beta firmware release.
2.Due to the extensive changes in this major firmware update, it is required that the user performs a "Reset Factory Defaults" operation after the firmware is installed. Please write down your special settings before doing this, and remember to re-apply your settings and adjust the proper volume level (if applicable) before you play any content. You may experience stability issues if this step is not performed.
Comparing to the previous Official release version BDP10X-67-1204, the major changes included in this version are:
1.Improved Gapless Playback performance and added Gapless Playback support for FLAC files.
2.Resolved several issues involving Gapless Player, such as the track title not getting refreshed in the Now Playing interface, and the player becoming unresponsive when trying to access a disc in the tray without stopping the currently ongoing Gapless Playback.
3.Resolved an issue with Gapless Playback with several customer-encoded WAV files. It was caused by an additional "List" information segment presented in the WAV file Header, and we have added support for this segment so that Gapless Playback now functions properly with these files.
4.Improved HDMI handshake performance for the HDMI input ports.
5.Resolved a compatibility issue with the HDMI 2.0 input port on some Panasonic 4K TVs. For example, the #4 HDMI port on TV model TC-L65WT600. This port contains additional Extended Display Identification Data (VSDB) blocks which caused our player to switch to DVI output mode and discard the audio packages, so there would be no audio from the TV speakers. We added support for these specific VSDB blocks and resolved the no audio issue.
6.Resolved a compatibility issue between BDP-103/105's HDMI 1 Output to the McIntosh MX150/151 AV Processors. Users reported no audio when using this combination, so we added special instructions for these A/V processors in the HDMI handshake process. We highly recommend that you contact McIntosh Technical Support to upgrade your MX150/151 firmware to the latest version.
7.Resolved the Wi-Fi connection failure with access points or routers using WEP security. This error was introduced by 67-1204 firmware and this version corrects it.
8.Resolved an audio truncation issue occurring with several DVD-Audio discs. Customers reported that the first note or two was cut off between track changes, and when the PREV button was used to restart the current track. Sample discs included "Queen: A Night At The Opera", "Buena Vista Social Club", "Beatles: Love" and "R.E.M.: New Adventures in Hi-Fi". This error was introduced by 67-1204 firmware and this version corrects it.
9.Resolved the playback failure with certain customer-encoded audio files in WAV, FLAC and AIFF formats. Symptoms included files being skipped, files being played with static noise, and files causing the player to freeze. The 67-1204 firmware adds more support to meta data tags in these files but encounters this problem if the meta data tags are in non-standard location. This version further improves the support for meta data tags and corrects the problem.
10.Resolved an audio dropout issue occurring with "Monsters University (BD, 2013)", related to its Dolby TrueHD 5.1 and 7.1 audio tracks when the player's HDMI Audio Format was set to Bitstream. We worked with Dolby and our decoder chip maker to address this type of audio dropouts.
11.Resolved an issue where a brief static noise could be heard when streaming music from a computer running Mac OS X to the BDP-105's USB DAC input. It could happen when the music stream was paused for a few seconds and then resumed, and it could be heard through the analog audio outputs, including the 7.1, Stereo, and Headphone outputs. We improved the audio muting logic and have eliminated this static noise.
12.Resolved an issue where a brief static noise could be heard when playing SACD discs in DSD mode on the BDP-105. This burst of noise was audible at the beginning of a track or when switching to the next track. It could be heard through the analog audio outputs, including the 7.1 and Stereo ports. We improved the audio muting logic and have eliminated this static noise.
13.Added 24 Hz support for customer-encoded video files in 480P24 and 720P24 formats. The original frame rate can be preserved when upscaling the content to 1080p, e.g., when Resolution is set to 1080P, the 720P23.976 content is output as 1080P23.976, and 720P24 is output as 1080P24. Previously, these formats were frame-rate converted to 60 Hz.
14.Added an "INSTANT REPLAY" function to video playback. If the customer presses the AB REPLAY button twice (two presses within 1 second), video playback will be automatically rewound 10 seconds.
15.Added support for playing CUE files and DSD64 files (.DFF and .DSF) over DLNA. The DLNA server must support these formats as well. A new version of oShare DLNA server that provides these functions is available now, and can be downloaded here from SourceForge.net.
16.Resolved a HDMI handshake failure when the OPPO's HDMI Output is connected to an A/V receiver, while the same receiver's HDMI output is fed back to the OPPO's HDMI input. We added special handling for this kind of "loop" connection and resolved the handshake failure. However, we highly recommend that you do not use this "loop chain" connection since it might cause unexpected HDMI handshake or CEC results, or even cause electrical damage.
17.Added indications on the front panel and TV screen for DSD file (.dsf, .dff) playback. If a DSD stream is output through HDMI, the "SACD" icon on the front panel will be lit and the TV screen will show the "Track Type" as "DSD". If a PCM stream is output, then both the "SACD" and "PCM" icons on the front panel will be lit, and the TV screen will show the "Track Type" as "DSD to PCM". This way, the customer will know whether a DSD-to-PCM conversion is happening in the player.
18.General disc compatibility improvements based on recent and upcoming Blu-ray releases as well as user-submitted disc samples.
All features and improvements of the previous firmware are also included in this version.
Roku 3 refurb 69.99 free shipping
Roku 1
