OTA Antenna Grounding question | SatelliteGuys.US
mechaley
12
If I mount an OTA antenna to a metal vent pipe on my roof, do I need a ground? I assume a vent pipe is grounded. :confused:
I guess I could verify with a DVM and the ground on an AC outlet.
I hope some installers can comment on this. My understanding is that you need to ground it separately.
still should be ground separately
OLN on USA, Bravo on Scifi
Vertical white bar on screen???
