OTA Antenna Questions...? | SatelliteGuys.US
alton987
54
I live in central Texas. All my Local HD satations are about 20-30 Miles away right now. I have no problem picking them up now. But some Austin stations are about 60 miles off. I think I can pick them up with the right Amp/Antenna combo. But the towers are in the opposite direction of my locals HD station towers. Does anyone know if this is doable without a Ant rotor.
You will need to figure out what channels are in which direction. If you luck out and VHF is in one direction and UHF in the other it is easy. If some UHF are in one direction, some in the other you can get UHF antennas that are channel cut (well about 5-10 channels). If they are not adjacent you might be able to get different antennas for each direction. Also do not forget that VHF-HI and VHF-LO can be separated easy too. You can also get single channel VHF antennas.
http://www.starkelectronic.com/btb1-1.htm
Voom Magazine?
Espn
