OTA antenna through DP34 | SatelliteGuys.US
wdr61
4
Hello,
OK here is what I want to do. I want to mount an OTA antenna on the roof. I want to diplex it with one of my LNB's and let the signal go all the way through the DP34 switch and just before my receivers I want to add a second diplexer to seperate the signals again. Will this work?
Option 2. Diplex the OTA with one of the LNB's and just before the switch add a second diplexer sending the lnb to the switch and the other to a splitter. Then on each output of the switch I add another diplexer combining the OTA signal from the splitter with the SAT signal. Just before the receiver add a forth diplexer to once again seperate the the signals. Will this work?
Obviously the first option is easier.
Thanks for your input.
Bill
The DP34 will not pass OTA TV frequencies, so option 1 will not work.
Option 2 seems like a lot of gyrations to go through just to play with diplexers.
It is so much simpler just to run a seperate cable for OTA and if you have any weak channels you may lose them in the diplexing. It may also reduce your satellite signal strength.
I would say to just run the cable, rolls of 1000 ft go for around $40-60 in local shops
like others said it would cause alot of signal loss if used with diplexers.
RF remote for 722k
Hard Drive Shot?
