C Chris1523 Active SatelliteGuys Member Original poster Mar 7, 2008 16 0 Apr 13, 2008 #1 I'm having a hard time to get the ota antenna to work with the vip 722. I got the antenna working before with the 722. Also, when I plug in the antenna directly into my tv, the antenna works fine. Thank you in advance
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Apr 13, 2008 #2 What input are you connecting the ota antenna to? What signal strenghth are you getting when you scan the channels in?
C Chris1523 Active SatelliteGuys Member Original poster Mar 7, 2008 16 0 Apr 13, 2008 #3 I am connecting it to the antenna input. I am not getting any signal strength.
G garys SatelliteGuys Master Sep 29, 2005 7,621 37 Greentown, Pennsylvania, United States Apr 13, 2008 #4 Did you scan or try to add manually?
rcwilcox SatelliteGuys Pro Jan 30, 2004 300 2 Apr 13, 2008 #5 are you sure you are set to OTA not cable?
KAB SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Sep 20, 2005 22,301 6,282 Fishers, IN Apr 13, 2008 #6 rcwilcox said: are you sure you are set to OTA not cable? Click to expand... This, and make sure you are not connecting to remote antenna jack.
