Use RG-6 cable and compression ends and your good to go.![]()
do as we say; not as we do....BBC comes standard with POS crimp fitting, not to mention the lead cable that's kinked in half. who would have thunk there would be problems?
Just in case this is not clear to everyone, this problem also affects anyone who had basic cable joined to a DirecTV line feed, as we did. (We used basic cable - which we pay for in our community whether we use it or not - as a backup source, given the frequent thunderstorms/thick clouds here in South Florida.)
We had no problems until this week, when we could not access all of the new HD stations. I thought it was a bad BBC, but it was not. A tech arrived this morning and disconnected the backup cable from the splitter. That solved it, though of course we now either have to run a separate line for the backup cable signal or just surrender that option.
In any event, the point is: If your DirecTV was hooked up the same way and you're having trouble with the new HD stations, that's the reason.
OTOH, there are threads here that claim that if you install the BBC before the DirecTV line hits the diplexer/splitter (in the attic or wherever), that might allow you to maintain full funtionality.
I haven't tried that, but here is one such thread:
http://www.satelliteguys.us/directv-hd-discussions/108822-diplexed-ota-new-hd-possible-i-think.html
LOL my wife was like "WHY YOU NEED A $3k laptop?!" I said "honey its HD" she rolled her eyes and said "you and your HD" hahahaha
Nothing looks sweeter than the 3d desktop effects on ubuntu at 1920x1200http://www.ramzmusic.com/pics/Screenshot2.png http://www.ramzmusic.com/pics/Screenshot.png
jimbo you wouldn't know the recommended voltage of the winegard OTA antenna DC would ya?
I've been cutting off and replacing that crappy connector on the BBCs.
Matt
Anyone notice that the cable itself turns in the casing ?
I'm figuring that , that cannot be good for them.Jimbo
In my situation that woulda put the B-Band converter outside. I mentioned a thread here that said it could go switch-side I think it was by Matt actually. The tech still went ahead and ran new lines straight from my OTA ant to my DVR's.
how does this look with 2 lines going to the hr20 from the switch? a picture is always worth a thousand words
What would you do if you had multiple HR20's. Would you use something like a splitter on the OTA before going to the diplexor>
I would have too(run a new line). Though others swear it works flawlessly, I personally don't think it could be so easy. Guess time will tell.
Not to be too much of a dummy here....but I've not been on in a few days. Is this thread saying that since we got the new HDs that our OTA won't work?
There's been many a post about folks not getting the new 103(b) channels and they find a diplexor on the line and they were installed by a D* installer, looks like all of them didn't get the word.
D*, though being the disputed "HD leader" is definitely the un-disputed "non-communication leader". As many in this forum have mentioned, when it comes to communicating, D* sucks. Think its hard getting accurate info being a sub, try being a tech! As a tech, I was only informed that the new birds would be using the frequencies truncated by diplexers about a day before installing the new 5 LNB dishes. How long do you think they knew? I could go on and on about the "oh well, let the tech deal with it" philosophy but I will spare you.
Limited time offer
