OTA STB problems | SatelliteGuys.US
OTA STB problems
MichaelJames
20
Cincinnati Ohio
I currently live 1/2 way between Dayton and Cinci. I am using 1 antenna for Cinci and a different one for Dayton. Using an A/B switch from Radio Shack on my Panasonic STB, this worked well.
The problem I have now with version 6.2 of the software is this:
*Note that I my installer some how managed to get all/most of the Dayton and Cinci stations read in, so they are all/mostly listed in the guide)
When I go in and scan the Cinci. channels (B Switch on Rat Shack switcher), it reads all of them. Then I go in and change the Rat Shack box to A for Dayton and rescan.. nothing comes up. If I then go into the other menu to look at the signal strength of a station I know is there (Channel 2 in Dayton), the Voom box tells me its a signal strength of 98. so then I scan again and its still not located on the scan. If I then go into the menu and use channel up to find the Dayton station, it does not pull up..says signal is not there. So I go back into the RF menu (I think that is what its called), it still tells me 98 signal strength on Channel 2 in Dayton.
Whats going on here?
Could it be a problem with Dayton not transmitting PSIP data? Are the Dayton and Cinci stations using the same RF numbers and you are mapped by Voom to the Cinci area?
Nope, I am getting all the PSIP data out of Dayton on my other Voom box..no duplicate channel numbers either. (I have 3 seperate Voom boxes)
Dayton and Cinci. are less than 60 miles apart and they have done a good job getting their setups done correctly..
Wow so this problem is only affecting one of your STBs? Sorry.. I am now forwarding you to level 2 tech support:
Ilya or Sean Mota.
I have 3 Voom boxes. The one upstairs is Mapped to Dayton and comes in fine. The one downstairs is mapped to Dayton and Cinci, but Dayton ones do not come in when I switch the antenna lead..
Why would an antenna switcher cause the box to become confused?
I am not sure on the one downstairs which was mapped first. The one upstairs is only mapped to Dayton.
When you check the OTA signal level in the Installation Wizard you must enter the RF number, not the channel number. For example, the RF number of your Dayton WDTN-DT channel 2.1 is 50 (according to www.antennaweb.org), so you should enter 50, not 2 on that screen.
Possibly related problem with OTA, need help !!
Since upgrading to 6.2 my box has developed a problem that sounds similar. No A/B switch in my case. I'm in the Boston area. I used to get 44.1-4 fine but now the box says there is no signal present on all 4 channels. If I go into the installer menu and scan it no longer finds them but when I look at the signal quality on any of these channels it says it's 98. When I first loaded 6.2 it worked for awhile but now it's dead. Rescanning consistently misses those 4 channels. Others in this area have replied that they still get the channels so it's not likely to be a PSIP problem here. Tried rebooting the box and rescanning. Nothing helps. :(
Locals locked in but no picture?
OAR question
