Other transponders on G10R | SatelliteGuys.US
playyymaster
100
Vancouver, Canada
To Iceberg and Pete....... :hatsoff: :hatsoff: :hatsoff:
my FTA setup is working like a treat! Thanks to you guys.
It's the one with a Fortec Lifetime Ultra and the Star Choice (beer cans)
My question is:
I get a low (50% and lower) quality on the 11720 TP so I can only see those channels when the sky is clear.
I get nothing form the 3992, 4100, 4180 TPs
Am I missing a setting? or do I need something else to get those TPs
Once again, thanks :D
KU channels use a 5 digit Frequency the 4 digit frequencies are C-Band (Big dish 6-10')
Two more things
I forgot to mention that the 11800 TP comes in clear at 76% almost steady.
Also, I have an old oval dual LNB DirectTV dish. Is it good for anything FTA?
Sounds like time for a new LNB, half the TP are strong and the others are weak on G10R......
Yes you can use a DBS LNB for some radio channels and Nasa and GOL TV.
Bigger dish :D
Seriously though, the issue is right next door (Dish 121), there is an 11724 frequency that seems to overpower the one on G10.
I know bigger dish would help
I have a 30" and the signal is about a 30…I have a 36" dish and its at 45
On both, 11799 frequency is 75-76 solid :D
There are newer low noise figure LNB's available but as the "Berg" said a bigger dish would be the best upgrade......
C-Band converting to FTA help. No signal
Traxis Help
