Outdated Peripherals | Page 2 | SatelliteGuys.US
Whether it's taking a series of screen shots with specific step by step instructions on how to make Acrobat/Acrobat Reader the default PDF Viewer because an update reset it to Edge
That's a four-step process (unless you do it the Windows way). Right click on a PDF, select properties, click on "opens with" change button and click on the reader. Going in through settings takes more steps and involves a whole lot of scrolling to get to the .pdf file type.
Please tell me that you don't paste this into Word.
The trick would be to prevent Windows from messing with your choices.
Right Click ->Open With -> Choose Another App -> Adobe Acrobat or Reader -> Check Always Use This App
It gets pasted into Outlook and Teams
I use print screen all the time. Scroll Lock is the button that confuses me, I've never seen it called for to be used in my entire life.
I've seen Excel nerds use Scroll Lock in worksheets, apparently it makes something easier. I have no idea how to use Excel for what it's designed for nor do I want to. I'd rather gouge my eyes out with a fork then work with spreadsheets.
Apple is trying to unload some Lumon peripherals:
Kindle e-reader owner's thread
