Figured.... Although if it can handle 4K bandwidth, it could certainly handle 2 HD streams for P in P.Nope the answer isn't soon, the answer is its not coming.
But isn't all the heavy lifting done on the Hopper?Figured.... Although if it can handle 4K bandwidth, it could certainly handle 2 HD streams for P in P.
Yes, but doesn't change my point.But isn't all the heavy lifting done on the Hopper?
Actually it does. The Hopper can't send PIP to the Joey via Moca and the Joey doesn't have the guts to do it itself.Yes, but doesn't change my point.
Why not? If the Hopper does all the work, then the so-called PIP is just one HD picture. Or are you considering that a 4K picture?The Hopper can't send PIP to the Joey via Moca
Because the software does more than just send a picture. It also allows you to swap, move the inset around, do side by side, etc. The Joey can't do those functions and you can't send that down the Moca....Why not? If the Hopper does all the work, then the so-called PIP is just one HD picture. Or are you considering that a 4K picture?
IMHO if the Hopper can do it for it's own output, it can do the same for a Joey as well and just send a picture. I've been surprised at how little processing the Joey's do. If you know better, then I invite your correction and explanation of what exactly a Joey does other than display the Hopper output.Because the software does more than just send a picture. It also allows you to swap, move the inset around, do side by side, etc. The Joey can't do those functions and you can't send that down the Moca....
Did you read that somewhere? 2 HD streams is 1/2 the bandwidth of 1 4K stream.The Hopper can't send PIP to the Joey via Moca
Well, that sure was an inscrutable comment! What change of technology? Could it have worked on a Hopper 1 or 2?There was a change of technology so it would not have worked with the Hopper 3.
I remember, perhaps incorrectly, that even the Joey would have 2 channel PIP (not Bar Mode), but that never happened, as well. The concern may have been with MoCA 1.1 with ALL the traffic of internet access routed from all Joeys to the Hopper for VOD and all the other multiple TV channels being sent throughout the home to all the other Joeys. However, since MoCA 2.0 with the H3, this can be easily handled, but it feels like Dish does not want to make the financial investment to make PIP on Joeys since the business is shrinking, not expanding. IIRC, Dish laid off a whole bunch of coders some years ago when the linear TV biz, and Dish, started going down hill. My sense is we are luck that Dish keeps things afloat these days. There just isn't the economic incentive nor real competition there was before streaming came along. Now, it seems about keeping the business afloat and not having as much money to spend on the latest and greatest tech, but keep doing just enough to keep reasonably current in tech.Figured.... Although if it can handle 4K bandwidth, it could certainly handle 2 HD streams for P in P.
Limited time offer
