Panasonic Release new Blue ray dvd player/recorder in Japa | SatelliteGuys.US
Not open for further replies.
That would probably be only 4 1/2 hours of SD, not HD. HD takes up 6 times the bandwidth that SD would so wouldnt that make it 45 minutes of HD space on a DVD if it can hold 4 1/2 hours of SD (depending on the quality of the HD).
If you guys would bother to actually check out the link - it breaks it out.
The discs are between 25-50 GB. The 50 GB disk CAN hold 4.5 hours of HD programming.
