Pansat 2700, help please | SatelliteGuys.US
jogon64
199
Northern Mexico
My pansat 2700 is displaying a signal level reading of 99% (which is not true) and a signal quality of 0% on any sat. The thing is it´s giving this reading all the time, even with no lnb connected! I have installed several different bins, factory and otherwise. I even jtagged it but no luck either. Has anyone experienced this problem before? Could it be the coax jack thing or whatever it´s called? Is there some part which can be fixed or replaced? I know I could get another one on ebay for not much $$, but I would like to bring it back to life. Blame my mother, she always taught me not to waste anything!! Thanks!
Typical issue with the Pansat 2500/2700 and Fortec Star Lifetime Ultra (same manufacturer).
Most likely a failed power supply. Check for correct voltages on the AC supply ribbon cable. Probably will find two capacitors with popped tops on the power supply that can be easily replaced.
Canada / Northern USA Signal Report Needed: SatMex6 KU
Harold Camping on AMC6 weak or gone?
