When I got my Pansat 3500 a little under 2 years ago I compared the blind search speed against my Pansat 2700 and the 3500 came out much faster than the 2700 as expected.
Now when I compare them (Both have the latest software from the PansatUSA website) the Pansat 2700 is much faster than the Pansat 3500.
Example: The Pansat 2700 has finished scanning (Finding transponders) one polarity and the 3500 has only scanned (Finding transponders) half the same polarity.
The only advantages to my 3500 is it has a SD card for loading channel lists and saving them (This is very important to me
) and it scans the correct names of the channels it finds (Also very important to me) .
SETUP: The Pansat 3500 is connected directly to my motor setup and the Pansat 2700 is connected to the "IF OUT" on the 3500.
Also I have tried using the "Restore Factory Defaults" option.
Do you think this is caused by extensive use, I used to blind scan the visible arc from my location daily plus satellites I am interested in multiple times a day? (Recently I have done less scanning due to other thing I have been working on)
Maybe it is time to open it up and take a look to see if there are any burnt or leaky components inside.
Thanks.
Thanks.
