Maybe it could be HLG HDR? Does anyone know if CBS has started adding it to their broadcast shows? Only TVs that support it would show it as HDR, and possibly only through the native app currently. Everything else would just show it as SDR.
Again, I receive HDR when it is HDR only, when it is available in both, HDR or DV, it goes to DV as my above photo showed with Seal Team.I don't know what HLG HDR is, but there has to be some explanation for what's going on.. my app doesn't show HDR for anything, but some movies trigger the flag. Bruce's app shows HDR for almost everything but it isn't clear if he's actually receiving true HDR.
Then why don't I see HDR on those shows but I have it on the movies P+ lists? Makes no sense and you have yet to explain a potential reason why.
HLG HDR is the broadcast standard for HDR. It is designed to allow one signal to contain both SDR and HDR information. If CBS has started including it in the shows they broadcast, then maybe they are starting to include it in those shows on Paramount+. Of course, the support for that standard would have to exist in hardware and software. It could be that Bruce has the right combination of HW/SW while the rest of us do not. The fact that his TV just says Smart HDR, instead of HDR10, HDR10+, or DV is what made me consider the possibility. Just speculation on my part, but it is all I can think of at the moment.I don't know what HLG HDR is, but there has to be some explanation for what's going on.. my app doesn't show HDR for anything, but some movies trigger the flag. Bruce's app shows HDR for almost everything but it isn't clear if he's actually receiving true HDR.
On DIRECTV the broadcast shows are HD 1080i.Maybe it could be HLG HDR? Does anyone know if CBS has started adding it to their broadcast shows? Only TVs that support it would show it as HDR, and possibly only through the native app currently. Everything else would just show it as SDR.
Because of the Paramount+ app for each device. It seems only the Roku app includes 4K HDR while the LG app and the Apple TV app only includes 4K with no HDR and the Amazon app is only HD on my Cube. The movies that are 4K does say Dolby Vision, at least on my Apple TV, which is also HDR but just Dolby's version of it. It would be nice if all of the different platforms Paramount+ app were the same.Then why don't I see HDR on those shows but I have it on the movies P+ lists? Makes no sense and you have yet to explain a potential reason why.
Maybe your devices do not support it.Then why don't I see HDR on those shows but I have it on the movies P+ lists? Makes no sense and you have yet to explain a potential reason why.
Yes, but with ATSC 3.0, you can have 2160p and HDR.On DIRECTV the broadcast shows are HD 1080i.
I thought the previous photos you posted were from your ROKU? Where were they from?Maybe your devices do not support it.
How many photos do I have to put up to show it is available.
Once I hook up my Roku back up, I will see if the HDR symbols that Paramount puts up on my TV’s app, is on the Roku’s app.
My TV has a 10 bit panel, from rtings’ review-Smart HDR isn't real HDR
"cheap "HDR" TVs use 8-bit color with dithering to attempt to fake 10-bit HDR, use settings like "vivid" and "bright" to create color profiles, creating this false marketing technique as if HDR is a filter."
I don't have ATSC 3.0 to check.Yes, but with ATSC 3.0, you can have 2160p and HDR.
View: https://www.reddit.com/r/tcltvs/comments/12hwqai/whats_the_difference_between_hdr_and_smart_hdr/
There are a number of stations broadcasting ATSC 3.0 actually. I wouldn't be surprised if the networks are getting ready for the transition.Nobody us using 4K HDR on ATSC 3.0 yet, AFAIK, so nothing to check
My TV which uses Google.I though the previous photos you posted were from your ROKU? Where were they from?
Once again-Obviously they do if movies on P+ trigger the HDR flag on my TV. If you're seeing "Smart HDR" on your TV, it's *not real HDR* see my link above..
I do.I don't have ATSC 3.0 to check.
It is just stations broadcasting their OTA signals, but up converting it to 4K.There are a number of stations broadcasting ATSC 3.0 actually. I wouldn't be surprised if the networks are getting ready for the transition.
Limited time offer
