Partial Signal Loss - Very Frequent | SatelliteGuys.US
fatpug
39
Here
Today I started getting partial signal lost at least every 15 minutes r sooner. When I checked the signal strength it looked ok (green). This has even happened on the 110 SD channels in additional to 129 HD channels. I already tried to unplug the 722k for around 5 minutes.
Normally my signal is very good. Any suggestions?
First thing is to check for obstructions, particularly trees. Go to where your dish is, is the sky clear or are there trees that with wind could obstruct it? You could also check that the connections everywhere are tight.
As others have mentioned in other threads, a weak OTA channel can possibly cause the message, even on sat channels. Do you have the OTA tuner module and an atenna connected to it?
Does Dish really install on weekends?
Philips sound bar hsb2313a and Dish Network
