Pausing on 722K | SatelliteGuys.US
Pausing on 722K
PJJAnthony
55
I'm still playing around with all of the features on my new 722K. When you pause live TV or pause a recorded show, is there a way to get rid of the pause bar at the bottom of the screen? Hitting cancel only adds more clutter on the screen (the title bar at the top). Sometimes I want to read something on the bottom of the screen when I pause, but can't, due to the pesky pause bar at the bottom.
Hit the frame advance (skip fwd) once and it will just leave a little arrow on the screen.
Yes, that gets rid of the bar, but it moves ahead and what I wanted to read at the bottom is gone. Hitting skip back doesn't bring it back to the exact frame. I guess I meant to ask if there is a way to get rid of the pause bar and stay on the same frame?
Tricky. But at pause, hitting fwd/rev will get you 1/4 or 1/15 frame movement.
If you hit clear after the pause/skip fwd, you can get rid of the small arrow, at least for a while.
This is one of those things that works 98%, for which I am grateful.
Installing a new Dish Turbo HD Dish
Program guide never good for more than 2-3 days?
