Not so easy to buy these items in the US. No one stocks them and Invacom USA doesn't even receive them from Invacom. They are forwarding my request along to Invacom central to see if there's a way to get them.
ADF-120 and TWF-031. You're right. There is one selling on eBay right now from the UK. Just bought it.
If you're looking at the same sites I saw, then if you dig deeper, you'll find that none of the places listing the item actually have it in stock. I called Invacom USA, and they do not receive these items from Invacom any more in the US. Invacom USA is actually some other company acting as an Invacom distributor.
It's at about -45. I can never remember which way is +/-, but if I am standing in front of the dish (blocking its reception), the LNB is rotated clockwise from vertical about 45 degrees. I have tweaked the skew while watching a meter and have peaked it with its current position.
The skew has a massive effect on the Q (if you rotate it back to zero, Q drops to near zero).
Thanks for your help. I'm getting Calidad that varies between 20-30. BER at the moment is 8.5E-4.
I have the satellite set to PAS-9 24K
LNB is set to Tono, Banda Baja: 9750, Banda Alta: 10600
6 foot dish with Invacom LNB. Getting great Q and signal with the large dish, but I'm definitely not in the middle of their coverage area.
Limited time offer
