I'm betting on that or the dish has slipped down a little I noticedI'm betting on a bad lnb.
That certainly could be an issue, but with the 100% signal strength it's not as likely.I'm betting on that or the dish has slipped down a little I noticed
Is 119 behind a building? Did you get a 3 or 5 lnb? If a 3 then there is no los issue.
My bad also the 119 is hitting the balcony above me. There coming out later to do a point and shoot. I know the wind blew it around a little bitIs 119 behind a building? Did you get a 3 or 5 lnb? If a 3 then there is no los issue.
i will ask about the monopoles!!! i noticed since relocating the tower the issue has stopped!!! will keep everyone posted. i also noticed after unplugging the tower it went through an update as well that might have been something also. i think they have rules on the tower placement also.John,
Don't worry about the location of the 119 Sat, your not using that Sat anyways ....
Everything your using is on the 3 Sats .... 99/101/103 which are clearly viewable.
I'd ask if they can use monopoles or something to support the dish better.
By the Tower, are you talking about the HS17 ? (I don't know what equipment your using).i will ask about the monopoles!!! i noticed since relocating the tower the issue has stopped!!! will keep everyone posted. i also noticed after unplugging the tower it went through an update as well that might have been something also. i think they have rules on the tower placement also.
I made the dreded call and made a service appointment for tomorrow. I'll post and let everyone know what happened
He called them two months ago!Before you have them come out, you should contact the local station and see if they are having trouble with their feed sent to Directv. That is probably the case and the tech will be able to do nothing.
Glad its working for you, do remember them saying to keep devices 3ft away from the TV and other like devices, I'm not sure if thats actually practical or not.when i moved the HS-17 tower from behind the t.v.. the breaking up stopped. i am thinking that there was some interference between the tower and t.v..... so far so good!!!
I remember them not wanting to put it next to my modem because of interference. I believe the distance is 3 or 4 feet away is what the tech told meGlad its working for you, do remember them saying to keep devices 3ft away from the TV and other like devices, I'm not sure if thats actually practical or not.
Limited time offer
