I thought Voom was initially advertised as the best PQ?Sean Mota said:12mbsp is the norm that everyone (including E* and E*) uses (except for HDnet).
barth2k said:I read E* uses 19mbps for their HD.
12mpbs if true is PATHETIC. No wonder most of the premium movie channels don't look a whole lot better than DVD.
vurbano said:I thought Voom was initially advertised as the best PQ?
Sean Mota said:That's not true... ONLY OTA will use such a bandwith and let me say that if you think that these channels are DVD quality then I must get my eyes checked.
Vreesar said:Only thing I can say to that Conjuror is that I am "One" of those people in "Denial". I see some issues on some specific channel's but nothing on the grand scale you are "supposedly" seeing. Either I'm blind or you have a 150' screen and sitting 4 feet from it.
If your that disatisfied don't hang around here and go back to dish full time.
Conjuror said:Voom's STB is motorola, isn't it?
barth2k said:You're wrong. Comcast (not all areas, but most) pass through the signal w/o further compression. Some other cable cos do the same. The only thing they do is encode and encrypt the data.
and like I said, E* is said to be using 19mpbs. Only D* is recompressing b/c of their bandwidth limitation. But that may change with the new satellite (or not).
You say V* is no worse than others. 1) wow, that's a nice standard to aspire to and 2) yes they ARE worse than some.
Conjuror said:Well, you probably should. Newer DVDs played on a progressive DVD player look better than most Voom's "exclusive" old, crappy, grainy, blurry, mono or stereo movies.
Pisses me off that some folks on this forum are in constant denial about Voom's PQ issue even after tens of people complained about it here. How can we then expect that Voom will recognize and address this problem when people like you Sean keep marginalizing our posts? There is problem with every Voom channel, including HDNews. This channel look somewhat better than others just because of the constant still picture and not very detailed background. We all know that 1080i works the best with still images.
I pay every month 10+ dollars for Dish's and keep 811 receiver (for which I could get 100-200 dollars) just because of Voom's PQ issue which, apparently, is not likely to be addressed in my lifetime. My anger about it is growing and I am every day closer pull the plug and go back to Dish or somewhere else where I can get some decent HD PQ. Many people already did so and many more keep their old HD provider for the same reason. I just don't see how they intend to stay in the business with this level of ignorance.
DarrellP said:Sean, maybe Conjuror's using a DVI connected upconverting DVD player while the rest of us lowly bums are using a pisspoor component connected progressive player? I have yet to see a DVD look as good as the worst Voom exclusive (except EquatorHD). I may change my mind once I take possession of the D3, if it ever ships.
Sean Mota said:Please post some back up data for your claim. The data needs to be current and you need to monitor the data over a period of time. Then take the average of that and come and post the data with your graphs. I also would like to know the equipment that was used to collect the data since every equipment has its own scale. Since you seem convinced that this is the case, let's post data analysis.
Conjuror said:That is not the point I tried to make but I clearly said that newer DVDs look better than those old, grainy, and mono movies..
Limited time offer
