Pictures 8' Damaged Dish | SatelliteGuys.US
WyrTwister
769
Thanks for all the help and advice . This is just a temporary instalation . A permant instalation will come as soon as I get a chance . :-)
Wyr
Good to see you have it up. I would find some stainless steel wire and tie across the gap at the top and in the middle.
Good luck with it.
Wyr
Good luck with it.
If you look on one of the photos , you may see a bungie strap on the broken rib . Need to make a couple of brackets on each side of the break . Then bolt/screw/pop-rivit the brakets in place .
Then make a part to replace the missing part of the rim . I have some galvinized roofing flashing sheet metal that I may use to fill in the gap .
Thanks to all for the help figuring this out .
Wyr
LinkTV...I just heard back, could go sat in June
New KU hookup, questions
