I am in south central PA. They slapped a D1000 up with my 6222 upgrade. I have a weak (80%) signal on 129. I wonder if I complain... If they will replace my 1000??
Here in the PNW we would be ecstatic with an 80% reading with a D1000 on the 129.
I would like to know myself. Did you use the same directions for skew and elevation for the old dish 1000? Those are damn good readings. I hope I can achieve the same when mine comes in from the dishstore.
The installer setup everything for the skew and elevation, I just fine tuned it after he left. By the way, it was mounted on an older Dish 500 Mast, so that seems to be working out fine.
Also, I am located right in the middle of Georgia, just south of Macon.
Where did the installer get the "skew", "Elevation" and "Azimuth" numbers from based on your zip code?. I notice my current receivers have that information for a dish 500, 300 or super dish only.![]()
Cool I am in the Beaumont, Pt. Arthur ,Tx area so I should see similar readings. By the way How did you fine tune the dish? Did you try peaking on the 119 or did you reaim using the 129 slot? I just bought one from the dishstore too and I will be installing it in mplace of my dish 1000 next week when it comes in.
I peaked mine using first 119. Then from there I made slight changes till I got 129 to go as high as I could. I ended up with 119 being up in the 100's and 110 being in the upper 90's low 100's.
One last question. Do you see that the 129 sat is still rising up and down on the signal strenths? Does your picture on the 129 sat pixelate or freeze with the new Dish 1000.2? Do to the wobbly satellite up there for 129 this has consistently been a problem and I wondered if this would be corrected with the new dish 1000.2?
This document should contain the data you seek:
http://www.satelliteone.com/dish/support/DISH_1000_Installation_Guide.pdf
ON EDIT: Dang that Randall is quick!! Now if only the thing worked up here in the great NW.
Mike,
Once you get yours pls. report back on the readings for 129. I'm interested in this new D1000.2 if the readings improveo on 129.
Here are some signal levels for everyone to look at with the Dish 1000.2. Now, I don't know if these are as high as they could be because it is extremely overcast and nasty looking here. But here are the signals for 129 and a few random ones for 119 and 110.
Satellite 129
T01 - 86
T02 - 81
T04 - 92
T05 - 86
T06 - 76
T07 - 81
T08 - 87
T09 - 93
T10 - 87
T11 - 78
T12 - 90
T13 - 97
T16 - 85
T17 - 89
T18 - 63
T19 - 95
T21 - 86
T22 - 80
T23 - 85
T27 - 84
T30 - 94
T31 - 101
T32 - 85
Satellite 110
T06 - 108
T24 - 101
Satellite 119
T02 - 116
T11 - 120
Limited time offer
