Please advice | SatelliteGuys.US
Please advice
volosator
Hello, I'm new to the North American sat tv. Another word, just moved to US. It's so different from European stuff. However, I can't live without sat tv. Can you point me to the right source on the internet with FAQs, manuals, etc for dish network eq? What's the yellow card, blue card, rom, etc.. It seems I can't find it myself. Thanks a lot!
You can find that information at dishnetwork.com under the "our products" tab then select which type equip your looking for. There is a pdf link to manuals at the bottom of each eq description there also. A good place to go from there is CNET.com where you can get unbiased editor reveiws of each box and compare with the competitors equipment. Hope this helps and welcome to the USA!
Jeff
Card stuff you don't have to worry about unless you're a hacker. DISH will supply you with the right equipment to get their service, including professional installation.
What Harmony remotes will work with a Vip622
Dish networl "connections" internet/ phone
