PMs | SatelliteGuys.US
PMs
Not open for further replies.
Never mind, it seems to work, it just doesn't say I sent it, or register toward my PM count.
I just noticed the same thing. The Miscellaneous Option "Save a copy of this message in your Sent Items folder." is probably unchecked....
That is correct, with the new 3.8 software the save sent PM's checkbox is now unchecked by default. Its a change that was made in the software and not one that I have made. :)
Additional Options
Yes, it's located down below the Submit Message / Preview Message buttons.
. . . . keep scrolling down and there are 4..5 check boxes in the section called: Additional Options .
You'll see.
Also, I asked the question about PMs the other day.
Guess I should have put it in the title of the post.
Hope others learn from my mistake. ;)
Favorites
Donating Pub membership
