I will have to poke around next week at the new house to look things over again. I did not think fonding a pole would be hard
Thanks for the ideas! I now have a few options
It would be much better if you can to mount on the side of the house. A slimline dish on a 5 foot pole will move a bit in sharp wind. During times of high wind days, I would often loose signal.
Jimbo said:Your not peaked very well then ....
I can go out and shake the pole and get the dish wablling and not lose signal.
Mine is on an 8.5 ft pole and has never lost signal due to the wind. I did take it down during Hurricane Irene.
All depends on the thickness of the pole, the amount of the cement used, and how deep the pole was burred.
Your about the same as mine is, but I went 30" deep.It's schedule 40, buried 3.5 ft deep with two 60 lb bags of Quikrete.
Like pipe, conduit comes in pipe sizes so there is no 2" OD steel conduit.
The 2" OD galvanized fence post remains the best answer.
raoul5788 said:They are plenty strong. If the pole isn't too tall, you can fill it with concrete. It will be very strong then!
Limited time offer
