Post your backyard/Roof Antenna, Dish, Tower, C-Band, Ku-band Pictures!! | SatelliteGuys.US
firstmode
76
Alright guys, lets see everyone's setup. I know you guys must have some impressive dish/antenna configurations and I would definetly like to see the hardware.
Post pics of at least your Antennas, DBS, C-band, Ku-band, etc.
if you want you can post pics of your TV's, Sat/Cable/OTA recievers, sound setups, etc. I will be posting my pics shortly, just have to find a place that will host them. I do not really have much stuff, but will post what I have
Click 'manage attachements' and you can add them to a post.
Here is my 'dish tree':
Shawn
heh, this gives me an excuse to take pictures of the dishes at the new place.. too bad I dont have them all up yet...
So far just the 60E for *C and the Dish500 for E*..
the FTA one should go up this weekend.
Here's mine:
Direcway .98 cm dish antenna
DISH Network SuperDISH 105
DISH Network 61.5 dish (Old VOOM dish with DishPro LNBF)
DirecTV Phase 3 Oval Dish
All on 2.5" OD Rigid Pipe, and an old Primestar plastic enclosure for the ground blocks
Heres mine.. The ota ant. is a chepy one I bought off of ebay... And it works great!!!!!!!! Notice the addition the the voom ant arm.. This works great for my apt install :)
Is the little roof on the side of the house one of the requirements when looking for a place? ;)
Do you find you get more gain out of the Dish500 with a single LNB? I tried this but I ended up with the same signal strength. The only way I figured it would help is if I could modify an adapter to move the LNB out a bit due to the 20 inch dish having a different focal point than the 18 inch dish.
Your neighbors must love you with your christmas tree outside! ;) I used to mess with my brother's next door neighbor at his apartment. His dish was right there next to the walkway as you walk through the apartments. I used to accidently hang his dog's metal food bowl on the LNB all the time.
I'll try to get pictures of my farm up soon... it'll have to wait until the weekend. It gets dark at 5:30p now....
Actually yea I get 125 + on most tp's (that dish is pointing to 61.5 ) and thats even off of a 942 :) the only tps that are lower (100's) are the tps coming off of rainbow1. aka Echo1 :) The neighbors dont mess with it at all they know that is someone touches it they die :) as much as i have been out there peaking things and messing with things..
So did you use a Dish300 mount assembly and just put a Dish500 "pan" on it or is that Dish500 assembly and pan?
No, but its an awesome bonus.. unfortunaetly, this house does not face directly south like the last place.. but its pretty close..
The entire 2nd floor is slightly smaller then the first, so I have this roof ledge all the way around.
Pics of setup
This is just some of my setup.
And some pics of the 2005 daytona 500 on fox in hd on my lcd.
Insight adds Fuse, MTV Español, ESPNU in Kokomo
ABC show Lost last week HD recording problem:
