Dish 500 on the left, Expressvu in the middle, 61.5 on the right, OTA for HD locals, Robomower going out to cut the grass.
I'm a lazy SOB!
I'm a lazy SOB!
Texanmutt said:Why not just get one of these-
http://www.winegard.com/home/76cm.htm
The model ds-2077 can be used with dish lnb's. you can get it for around $40- $50. Not to mention you would never have rain fade w/ a 30" dish.
Mike500 said:Here's my Dish500 and my OTA antenna.
The Dish500 has been painted with satin white Krylon "Fusion" paint.
I know that many of you will ask why I did not mount to the brick or the vinyl siding. The brick foundation mounting would have been too low, due to children paying in the back yard. The wall is full of water supply and drain pipes; some with horizontal runs trough the studs, making weak structual support areas. Also, the electrical panel and wires are in that area. Screws may have penetrated any of them.
Both the satellite pole and the antenna mast are scedule 40 aluminum pipe and will never rust.
All connections and grounding blocks are in Telecrafter Omni III weatherproof boxes.
digiblur said:You might want to check that coax going into the brick. No drip loop there.
digiblur said:Why do the neighbors always look at me funny when I leave for work in the morning?
goaliebob99 said:Heres mine.. The ota ant. is a chepy one I bought off of ebay... And it works great!!!!!!!! Notice the addition the the voom ant arm.. This works great for my apt install![]()
HokieEngineer said:Maybe cuz you have indoor couches sitting in the backyard??![]()
dodge said:This is just some of my setup.
And some pics of the 2005 daytona 500 on fox in hd on my lcd.
Parlyle said:I see you have NO guy wires. Don't you need them when the winter winds blow from our Wisconsin plains into Illinois? Just wondering.
Thanks for the pix.
Lyle![]()
ultatryon said:That tower is quite short.. I would guess 35 feet or so.. it barely goes over the roofline. If it was bolted to a cement slab, or even built into a cement base, there would be no need for guy lines as its simply too short.
dodge said:Lyle
by the way where up in packer country are you located??
Limited time offer
