I did the kill-a-watt test on my 722 and if I remember right it was round 50-60 watts while running. I don't remember it being in the 80's.
Yep, my 722 draws 50 or 51 watts, 2 or 3 watts less when in stand-by
Hi, that looks about right for the Dish receiver. BTW - my FTA receivers draw less then 5 watts when turned off using the remote. It does take a couple of seconds for the FTA receivers to come back on, perhaps that's why the Dish receiver was designed to stay on all the time but is sure seems like a waste IMO. DC
Unfortunately, the project managers in-charge of these receivers design had a vacuum tubes mentality.Well thank goodness they don't have tubes.........
It's a DVR, and has to stay on to record programming at any time.
While out might be possible to lower the consumption, it won't get down to a few watts.
Not a huge amount compared to what you pay dish per month to use itSo I guess we are down to 50w * 24hr/d * 30d/mo *$.1/kwh = $3.60/month
-Ken
While it could power down disk and electronics, would you want that and possibly miss a recording?
What is the difference in disk failure rate from cycling?
-Ken
Riah said:Not a huge amount compared to what you pay dish per month to use it
And just think, all of the DVR manufacturers are too inept to solve this "problem."...in wasted power cost. ...
If your laptops were being used as DVRs, you could never turn them off.If our laptops were designed by the same engineers that designed these Satellite receivers, our laptops would have been dead 2.5 hours after we turned them "off"!
That would be for both the E* and D* boxes processing up to six signals simultaneously? (Simultaneously recording four signals while watching two different previously recorded events?)...D* DVRs use half the power the E* DVRs use. ...
I must agree with most of you that E* DVRs are very inefficient when it comes to power consumption. Directv new DVR receivers on avearge only draw 24 W when on and 22 W when off. Some say that's because the new D* DVRs do not have an OTA tuner built in but how much power will the OTA tuner use? D* DVRs use half the power the E* DVRs use. And D* receivers are also on all the time for updates, timers, etc....
http://www.energystar.gov/ia/products/prod_lists/set_top_boxes_prod_list.pdf
This is true DirecTV DVRs are Energy Star rated.I like to believe the reason for this is to help the DirecTV subscriber save money so they can afford the higher programming costs that comes with a DirecTV subscription?.![]()
Limited time offer
