Power Down Dish 301? | SatelliteGuys.US
hotwire132002
105
I'm trying to turn off my Dish 301 so I can upgrade the software. (It's running 2.03). How the heck do I do that? The best I can figure out is hold the power button to restart it, but I can't make it turn off and stay off! Any advice?
The off button on the remote?
Seriously the unit just needs to be in standby. If you want to use the power button on the front of the unit just press it once and don't hold it in. Wait 15 or 20 minutes and the unit should upgrade.
NightRyder
NightRyder
No go. The unit stays on. :confused:
811 problem
Is a Quad LNBF standard or extra??
