Powertech DG 280 question | SatelliteGuys.US
TimLones111
453
Canton, Ohio
Hello:
I am going to attempt to put the motor on the dish today, but I have to set the motor back to 0 first. Where do you connect the motor to the receiver on the inside of the house to do this?..Thanks for your help..
BTW, the Receiver is the Fortec Dynamc
In the receiver's Antenna Setup Menu, look for "Go To Reference" in the USALS area.
What I'm asking is about the coax cables..I have the motor in the house at the receiver..The LNB coax is at the LNB side of the motor..Have it on USALS..nothing as yet..Where do you put the other coax?..
on the motor there are two spots to hook coax into 1 is LNB the other is REC(receiver), in order to move the motor the coax needs to be hook up to the one that says REC(receiver) then it should work
Thanks for the help guys..
I called Sadoun about this, and I finally got it straightened out..connect the Receiver port on the motor to the digital line in on the receiver, set up USALS, and..we're now back at 0...I made it a lot harder than it had to be..again, thanks a lot for your input..
New FTA Channel Idea
Recommendations? (New reply, old thread)
