Problems Setting up Oval Dish | SatelliteGuys.US
mjmoens
2
Hello, I am looking for detailed instructions of how to set up an oval dish. I understand the elevation settings, but the azimuth and tilt are a mystery to me. Please advise as I did not see detailed instructions on D'TV's web site.
TIA Marshall
TIA Marshall
what major city are you near?? il send you the info
I am near San Luis Obispo, CA (Cayucos)
Thanks for the link on the instruction manual. Starting to make sense although the tilt is still a little fuzzy to me. I may be posting back. :)
I get slightly differant nbrs on a look-up on my receiver for zip code 93401
San Luis Obispo Ca.
Az 147.4
El 47.6
Tilt 104.5
F.Y.I.
Not doubting you at all....just saying what my receiver reports when I input the
zip-code 93401....Don't know how far San Luis Obispo, CA , would be from LA and
if it's enough to make a differance?
Is he looking for AT9 or Phase 3? Yes he should be doing AT9 but from his post the Phase 3 looks more likely. Seeing the Phase 3 is centered on 110 and the AT9 uses 101 the settings should be different.
Strange issue with DVR+ remote
2 sattelite dishes 1 switch poor picture, perfect signal?
