Problems w/ 811... | SatelliteGuys.US
Problems w/ 811...
ChadH
27
Chicago
I've got 2 problems: OTA signal strength is fluctuating all over the place and others in Chicago are not having problems (I'm 10 miles from the towers). The modulated output has sound, onscreen info (from the 811) but no picture for either OTA or SAT broadcasts. I only noticed the second problem this morning and didn't have time to reset the receiver or anything. Resetting will probably fix it, right?
Hold the power button down for about 10 seconds to reboot the 811. That will clear up the Sat pic. Adjust your antenna to see if the signal stablizes and connections.
942 and SW64 WITH LEGACY LNB
called to upgrade--now I'm cancelling service!!
