Program Planner | SatelliteGuys.US
Program Planner
DarrellP
I Think, therefore, I am.
4,298
Salem, OR
This has been beat to death in the Wish list forum, I just wanted to make it more visible and get your input on this ONE topic, please don't dilute it with off the wall crap, thanks.
The Program Planner. Very crude, very rude. Most of the time it works, sometimes it doesn't.
It will not work with PlayboyHD, the stb appears to freeze, but a Power off and back on and all is well.
My Wish list:
1) Put a timer indicator in the EPG for a Programmed Timer.
2) Put the time duration in the Program Planner info.
3) Make it easier to get to the Program Planner.
4) Make recurring timers: Daily, Weekly, etc.
5) Make it popup/tune quicker than 15 seconds prior or give an option for adjusted time.
Please add to the Wish list.
Darrellp,
good list. I am told that in the new software the Program Planner will work with PlayboyHD. The others I do not know if they will be able to make it to this new release.
multiswitch questions
Help. I had to reboot and it never came back up.
