Programming Guide Not Correct | SatelliteGuys.US
AlexTheOne
88
I am wondering if anyone else noticed discrepancies in programing guide schedules where especially some channels are not correctly showing programs and times under the programming guide of that what is actually shown on that channel.
For example Ultra HD is almost always out of synch, they would show one thing but guide would be telling you completely different thing...please note that not all channels are doing this so I am not sure what, if anything, can be done to fix this issue.
Thanks.
Dish does not generate its own programming listings, they purchase it from a supplier just as TiVo and TitanTV do.
Thanks.
Yes, you're absolutely right. I've noticed incorrect program descriptions as well as (on my 622) the guide incorrectly tagging New shows as old and vice versa. It's caused me to miss more than one episode of some of my favorite shows.
I know have to double-check manually to see what's ACTUALLY on the channel. That's so, oh.....last century. :)
=NLK=
I have also noticed Glitches with the VIP622. For some reason it will not allow me to record Robot Chicken. It always records Metalocalypse. It finds Robot Chicken when you do a search. After setting up to record it switches to Metalocalypse.
Does your 522 search the locals?
New HDTV and Dish
