Programming Remote for VIZIO TV | SatelliteGuys.US
GSH
13
Pine Mountain Lake, CA
I have a Vizio P50 Plasma TV and Direct TV H20 Receiver. When I enter the Direct TV Menu OSD options for programming the remote to work with the TV there is no Vizio option listed. Does anyone know of a work-around?
George
George
Check www.remotecentral.com They may have an answer for you. Good luck!
George
Vizio uses LG componentss including the actual display on both 42" and 50" Plasmas, as well as the 32" and 37" LCDs.
I have program my 42" vizio on my H20 remote and it worked fine. Just scroll down the list on your H20 and look up LG codes.
Good Luck.
Fired!!!
D10 Power Cord. Where to find one?
