That is what is being checked. The DNS Feeds are on a single transponder and in HD. What could be the receiving differences between that and a Spot Beam transponder?but those are distant feeds......doesnt PTAT only record the LOCAL HD feed?
For anyone that is having the same problem listed above, please send me a PM and include the following information:
-Phone/account number
-What happens when you try to view something in PTAT
-Please verify that you receive HD locals
-Satellite setup (orbitals that you currently receive can be found in menu-settings-diagnostics-system info, or in the point dish screen)
-When you first enabled PTAT (must be enabled at least 20 minutes prior to events starting in order to work the first day)
-Software version
Also, please make a public post in this thread
Ok so I think I might have found part of the problem I am having with PTAT. Flint MI locals come off 61.5 transponder 3. They all come in fine and I have had no signal issues but when I go to point dish in the settings 61.5 transponder 3 shows 0 signal on all three tuners on both of my hoppers. I'm thinking that since point dish thinks I don't get a signal from the transponder that carries my locals in HD my hoppers think I don't get them and they don't fire.
Like I said. My signal is fine. I just set recordings for 3 of my HD locals so I could make sure all 3 tuners are getting them and all 3 recorded and looked normal when played back. I don't know if this is the cause of my problem but it seems like it could be.
Also, my installer took out my old EA 3 LNB Dish and replaced it with the 2 LNB EA dish because he said I didn't need 77 and he could peak 61.5 and 72.7 better this way. I watched him switch out the dish but when I do point Dish it shows signals on some transponders on 61.5, 72.7 and 77. If I understand this correctly I should no longer be seeing 77 right?
Can anyone with the newer 2 LNB EA Dish and a hopper confirm that their check switch or point Dish is no longer showing a signal from 77?
For those of you that can't get PTAT to record properly what is your signal reading for the transponder your HD locals are on? Mine shows as 0 even though all my HD locals come in fine and I have no signal problems.
I believe this is what is preventing PTAT from working on my Hoppers. I think that my hopper thinks I don't have a signal on my local HD transponder so it doesn't fire.
To see the signal level for your HD local transponder tune to one of your HD locals then push menu - settings - diagnostics - point dish. It should automatically test the transponder for the channel you were watching.
I don't have a wing dish. My check switch details just says error: removed duplicate 61.5 satellite on port 4. I have the EA 1000.4 dish. There are only 3 cables coming from my Dish to the duo node. Does this mean the diagnostic is just incorrect? I don't see how it would be possible to have 61.5 on both ports without a wing dish.
Maybe my LNB is bad but that seems weird because I am able to watch and record my HD locals on all 3 tuners and I haven't had a single signal problem since my hopper install. All individual timers and live TV has worked flawlessly so far on both hoppers but PTAT has only recorded 1 out of the 4 days I have had the hoppers.
It recorded on both hoppers my 2nd day after install but didn't work the first and hasn't worked since. I have done multiple hard and soft resets. PTAT doesn't show in my scheduled recordings except for the one day it actually worked.
After it didn't work again last night I deleted all timers on one of my hoppers, turned off PTAT, restored to factory defaults, and did a hard reset. When It was done I turned PTAT back on but didn't restore any other timers. We'll see if it records tonight but it was not listed in my scheduled recordings this morning so I have my doubts.
Like I said and almost every one ignores. When you set a timer for the last show in the PTA and add the 60 or 90 minutes THE TIMER STOPS when PTA ends.
FWIW, neither do I! Good luck tomorrow.
So I got my new LNB installed at about 7:30 this morning before I went to work and my signals are still coming in good including my HD locals. I gave it a couple hours and came home during my lunch break to check on it. I'm sad to say that I don't think the new LNB fixed my problem. PTAT is still enabled on both hoppers and I did a hard reset on one of them but PTAT still doesn't show in my scheduled recordings and the PT logos still don't show up on my guide for the PTAT shows. This has me thinking that PTAT won't record again for me tonight but I guess I won't know for sure until 7:55.
I'm hoping that it will work tomorrow after everything shuts itself down, reboots, and downloads new guide information at 1:00am tonight.
Limited time offer
