Hi cvbyte
1_download lmedvbs_fw.zip and unzip it in (/home/youname)
2_enter to this folder:lmedvbs_fw
3_open the terminal and write :
cd ~/lmedvbs_fw
chmod +x lme2510_fw.sh
./lme2510_fw.sh
sudo cp -vf *.fw /lib/firmware
Linux media remotes have under gone significant changes recently and many user applications are broken. If you are using less than kernel 2.6.31 it is possibly completely broken.
By default lirc is loaded when the rc_core module is loaded. However, many applications do not support the capture keys.
keys 0-9 should work in Kaffeine and power, volume -/+ buttons the desktop.
Test this, open terminal and press the number keys.
There are three known types of remotes with the QQBOX/DM04, it is possible there are more.
Hi all!
I have installed in debian, arch linux and now in lasted ubuntu and in all i have the same problem. I have cuts in the image and sound, seems to be the signal low, or a short buffer, I don't know. In other sofware like Kaffeine or me-tv, witch the same driver the device work successful, It's strange!
I have tried VDR, the problem is that it keeps trying to change pids while the streamer is running. I am not sure what it is doing, but it gets to the sixth pid entry and keeps swaping for pids on other channels.
His Linux driver will do Diseqc 1.0 / 2.0 and 1.2 to drive an H-H motor. It already works with Diseqc switches using factory driver.
Limited time offer
