Question about 722 installation | SatelliteGuys.US
kirbyhawk
38
iowa
I have a 622 right now and love it, but I would like to have access to the HD VOD service that will start up soon. I was thinking of upgrading using the dish-n-it-up promotion.
How hard is it to install the 722 myself? Or should I have it installed for me? Is it as simple as switching out the boxes and turning it on - or is it more complicated than that?
Any help is appreciated.
If you upgrade through Dish'N It Up Dish, they'll install it for you. Installation should be as easy as moving the cables from the 622 to the 722.
It is also possible to self-install, but you have to convince them that you know what you are doing. So........looks like either they come to your house or you spend a few more hours on this forum studying before you talk to them.:up
When Should I Expect My Box?
How to setup remote control to control my receiver?
