Question About Broadcast? | SatelliteGuys.US
stevelite
217
Hello,
If broadcast feed is say 720, but your TV only supports in 480 and 1080, what happens? Will TV adjust down to 480 or will try to display at 1080?
Stevelite,
Most likely your tuner will output what ever it is set for and do the conversion. If you have it set to pass through whatever resolution and your TV is able to accept the reolution, then the TV does the conversion.
