Question about my Directv Remote.......... | SatelliteGuys.US
98Civic
18
Greenville, NC
This might be a dumb question but I was wondering how do you know/or how can you tell when your batteries need replacing in your remote control? Thanks!
Sincerely,
When it stops working or doesn't respond to button pushes.
when the last time i change them, i got message on mine screen about it, i don't if that normal or just weird
Mine does similar things. Some functions will work, others won't. I just change batteries and all is well.
DTV Cinema/Cinema Plus
Love direct despise pricing
