Question for 721 users | SatelliteGuys.US
kwd57
31
Has anyone tried using the "record entire event" function in the record/options screen, if so did it work or crash?
Sorry, I meant to say after the L174 download
Mine works fine sometimes and other times it will not stop recording until you stop it. Thats my experience with my 721. They put an update out and everything works good and then they do another one and stuff goes bad and then yeah you guessed it it goes bad again.
I love my 721 but sometimes these sw updates drive me crazy.
DVI, component or composite for sd content
Remote Programming Question?
