Question fr m a newbie! Can I use a existing outdoor antenna? | SatelliteGuys.US
TxLove
Cushing,Tx
Hi Guys! I have a question, I recently moved into a house and there is an outdoor antenna already in my yard. Could I use it? I looked for wiring and it look like some have been cut they are white and black and look thin so I'm not sure if they even go to it or not. We think it's the 60 mile RCA antenna you can purchase at Walmart. Thanks!
:welcome to Satellite Guys TxLove. I would think you can use the antenna. It would be good to post some pictures of the antenna and wiring you mentioned. That would give us some more to go on. Also this FTA forum is more to do with satellite broadcast and not OTA which is what your question concerns. A mod may move this post to that forum. This will give you an opportunity for more people to help out.
sure you can use the antenna. I would check to see if there are any elements broken on the antenna. Also I ran a tvfool report for your location (cushing, tx) and it looks like you have stations in different directions
if you could post your tvfool report that would help too
www.tvfool.com
New to antennas, please help!
First thread in Rabbitears
