I was at a local dealer lately discussing upgrading to the 722 and I wanted to double check here to see if what he told me will in fact work. Currently I have one HD set in my house and three SD analog sets. I will be hooking up the 722 via HDMI to my HD set. OK, now here's where I'm double checking what he told me. Since I'm going to be keeping my SD sets around for a while, he suggested coming out of the SD side of the 722 to a splitter, and then to the other three sets. OK, no problem there of course. He then told me that each of the other SD sets would have access to either tuner in the 722, depending on what channel was assigned to each side. So for example, my wife could be watching the SD set in the bed room via the SD side of the 722 and I could be watching the SD set in my office by either using the same side of the 722 (which would be the same program as she was watching of course) OR I could access the HD side of the 722 from the office tv (even though it would be a SD signal) and watch a different channel. Is this correct
If so, I could get by running the entire house with the 722 only, until I eventually upgrade one of the SD sets to HD and then I realize I would have to add a second HD receiver.
