If things go as scheduled, it will start testing at 67.1W on Oct 11. Give them a couple weeks to check it out and then another couple to move it on to 77W.
So, a fair guess would start around mid November. Could take less time, could take more time.
For those that do not need the specific dBw curves shown on Satelliteguys SatMaps.
The service area photo encloses the area expected to receive Quetzsat 1 using a "standard" Dish antenna.
The large antenna photo shows the reception area using antennas up to 6 or 8 feet in diameter.
Again, the satellite has two beams, East and West, the only significant difference being the East beam can be received in Bahamas and Puerto Rico/Virgin Islands with a large antenna.
the mexican service with 8 transponders will count with twice the capacity which it has today?
E8 has 32 operating transponders. Quetzsat the same so no chamge there.
The only absolute change is the area covered by the beams
Dish has use of 24 TPs in the U.S. but because of the dual polarity design, Dish effectively can use 48 TPs in the U.S. This is a lot less capacity than what a today's typical spotbeam satellite can provide but it is more than what Dish is currently using at 77 W.
Do we have any more up to date launch times?
simonhwsn said:Once I asked
Then nelson replied
But then again...
I still can't understand this. What's the real advantage? the two beam maps look very, very similar, so what's the point of having two beams?
post #3 77W to Replace Echostar 8What satellite is this replacing or is a new location? ty for help and reply![]()
Limited time offer
