R16 question | SatelliteGuys.US
R16 question
Katz
29
I am considering upgrading my old sd receiver to sd dvr and have a couple questions.
1- will I get the R16 or are there still R15 out there? (I have read so many problems with the R15)
2- is it true that the R16 only requires one line run to be able to use both tuners?
3- are there any issues with the R16?
Thanks!
Thanks!
Pray for an R22. Thats all I can say. R16 is slow to respond to any command. as far as I know r-16 still needs 2 wires for full function.
Either way you would still have to purchase a single wire Multiswitch even if the R16 is compatible with using a single wire.
IMO the R16 is the same as the R15. Just a different color.
HD DVR Receiver Cannot Find Satellite, Other SD Receivers Fine
HDTV upgrade for 2nd receiver
