RE: [VOOM] Re: OTA reception | SatelliteGuys.US
C
cutestew1962
Guest
[VOOM] OTA reception
One member on SatGuys mentioned that VOOM could shut down the
receivers after 1-31, then you would lose OTA reception. He
suggested disconnecting the sat. cable and leaving the box on to
keep receiving OTA channels. How can VOOM do that? Can they send a
signal down from the satelite to disable the receivers? What can
they do through the phone line? Should we disconnect that too?
Re: [VOOM] OTA reception
Why would they do that? Another rumor? If there is any doubt disconnect
the Sat cable and the OTA should still work according to most theories.
----- Original Message -----
To: <VOOM@yahoogroups.com>
Sent: Saturday, January 29, 2005 4:43 AM
Subject: [VOOM] OTA reception
> Yahoo! Groups Links
RE: [VOOM] OTA reception
Voom is on the record as saying they will continue service during the
transition period. The post(s) on Satguys are nothing more than half-baked
speculation.
The deal is not done. It must get approved by the FCC, for one. How do you
think that would look when they marched before the agency and had to answer
for cutting off current customers?
I wouldn't worry about it.
Bob
> -----Original Message-----
> From: thegrod [mailto:bruceg@htva.net]
> Sent: Saturday, January 29, 2005 8:59 AM
> To: VOOM@yahoogroups.com
> Subject: Re: [VOOM] OTA reception
> doubt disconnect the Sat cable and the OTA should still work
> From: "cutestew1962" <cutestew1962@yahoo.com>
> suggested
> > disconnecting the sat. cable and leaving the box on to keep
> receiving
> > OTA channels. How can VOOM do that? Can they send a signal
> down from
> > the satelite to disable the receivers? What can they do through the
> > Yahoo! Groups Links
I agree with you again Bob, but if it makes people less nervous let them
disconnect Rainbow 1 on the 31st. I have no intentions of doing so. In
fact, the VOOM installer is coming on Monday AM to install 2 more receivers
adding to my original one and do an OTA antenna upgrade. I am taking
advantage of the $1 promo on right now. I will be agreeing to 6 months of
subscribing with the promo. Obviously, if they stop providing service, I
don't have to keep paying for that subscription but I suspect VOOM service
will be there the whole six months. Maybe a name change or new management
though....
Sent: Saturday, January 29, 2005 9:02 AM
Subject: RE: [VOOM] OTA reception
> speculation.
> answer
> Bob
>> suggested
>> receiving
>> down from
>> > Yahoo! Groups Links
>> ------------------------ Yahoo! Groups Sponsor
>> --------------------~--> Has someone you know been affected
>> by illness or disease?
>> Network for Good is THE place to support health awareness efforts!
>> http://us.click.yahoo.com/rkgkPB/UOnJAA/Zx0JAA/EyMolB/TM
>> Yahoo! Groups Links
> Yahoo! Groups Links
My OTA is no longer working, so they definitely disabled it. I had
VOOM turned off until the DVR is available, and OTA worked for
several months, but suddenly the screen now says that it's not
authorized. What really pisses me off about the whole thing is that
I paid the full $800 for this, and the box should continue to work
regardless if VOOM is around or not (for OTA reception).
You canceled and that was part of the service
_____
Sent: Monday, January 31, 2005 5:00 PM
Subject: [VOOM] Re: OTA reception
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129ngg5ah/M=298184.5639630.6699735.3001176/D=gr
oups/S=1705036932:HM/EXP=1107298847/A=2532114/R=2/SIG=12kiigind/*http://clk.
atdmt.com/NFX/go/yhxxxnfx0020000014nfx/direct/01/&time=1107212447521108>
<http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=groups/S=
:HM/A=2532114/rand=514408335>
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
* To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<mailto:VOOM-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
[Non-text portions of this message have been removed]
Does anyone in this newsgroom not have common sense? LOL
Matt
Sent: Monday, January 31, 2005 5:24 PM
Subject: RE: [VOOM] Re: OTA reception
_____
I think common sense is not cancelling because of VOOM's lack of a DVR.
If it helps I agree with you. Since you bought the boxes for $800 you ought
to be entitled to use them for OTA, with or without a sub. VOOM clearly
doesn't own the airwaves or the equipment, just their service and OTA is not
deeded to VOOM for sure. I honestly believe the FCC would agree too, if
they cared about such a small minority.
Sent: Monday, January 31, 2005 10:23 PM
Subject: Re: [VOOM] Re: OTA reception
> Matt
> From: Eric
> _____
> From: lets_c_1 [mailto:dnewell@usa.com]
> ADVERTISEMENT
> _____
> Yahoo! Groups Links
> Service
> Yahoo! Groups Links
> a.. To visit your group on the web, go to:
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> Yahoo! Groups Links
Check with the FCC
Hi:
Check the FCC regs regarding set top boxes that receive OTA signals. They are pretty clear in that a box must receive all available signals (meaning it can't exclude some channels) and I think that you should be protected in that a third party (VOOM) can not block your OTA reception to equipment that you purchased. One can also make the argument that if VOOM is now failing to provide the program guide for the OTA channels then they should modify the box to receive the program guide information that is included for free along with the OTA signal from each station as this a part of the signal.
This is not a minor issue as there are probably a couple of thousand VOOM customers with purchased boxes that are entitled to receive their OTA signals should VOOM cease operating.
When I read your note I quickly turned on the TV to make sure I still have
OTA signals and I did. I'm in Forest, VA.
Sent: Tuesday, February 01, 2005 9:15 AM
Hi:
jnardone
This message was posted via http://www.satelliteguys.us by jnardone
_____
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Still have OTA here in Cleveland.
> From: jnardone [mailto:satguys2004@yahoo.com]
> Hi:
> jnardone
> _____
> Yahoo! Groups Links
> *Yahoo! Groups Links*
> Service <http://docs.yahoo.com/info/terms/>.
> I did not pay $800 I paid $1 and love my Voom service. Yes I wish they had a DVR but maybe they will if the service continues.
Matt
> From: "thegrod" <bruceg@htva.net>
> Date: 2005/02/01 Tue AM 07:08:33 EST
Hi Again:
The FCC reg is Section 15.117 regarding television receivers. Since the VOOM box was sold as both a satellite receiver and a television receiver it is subject to the regulations regarding television receivers.
...The reference in this section to TV broadcast receivers also
includes devices, such as TV interface devices, that incorporate the tuner portion of a TV broadcast receiver and that are equipped with an antenna or antenna terminals that can be used for the off-the-air reception of TV broadcast signals....
...TV broadcast receivers shall be capable of adequately receiving all channels allocated by the Commission to the television broadcast service......
...TV broadcast receivers are required to provide useable picture and sound commensurate with their video and audio capabilities when receiving digital
television signals..
I believe that I have common sense...
I had them disable the service as I was at my other house during the
summer. I suppose I should have continued to pay for the service
even though I wasn't here....
In any case, I DID pay $800 for the box, and OTA is not part of their
service, the box is receiving local channels, and has nothing to do
with VOOM other than the box receives the channels, and I own the
box. Now why do you think that because I stopped VOOM, I should lose
my OTA channels?
I agree completely and if I were in your shoes I'd be filing a lawsuit
against Voom.
Thankfully I did the rental so I didn't lose any money.
Robert
_____
Sent: Tuesday, February 01, 2005 7:03 PM
my OTA channels?
_____
Yahoo! Groups Links
I did the rental also so I was thinking along those lines. Voom owns my box abd if I quit paying then they shut the box off.
Matt
Sent: Tuesday, February 01, 2005 5:02 PM
my OTA channels?
Yahoo! Groups Links
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Robert,
I think you are 100% right. He should demand every cent of his purchase
money refunded for starters and go from there. If he bought the box from
VOOM they don't own it any more and they don't own the OTA channels either.
The only thing they are right to turn off is VOOM service itself. I wonder
what the FCC stance would be? Or the local affiliates?
Sent: Tuesday, February 01, 2005 5:11 PM
> against Voom.
> Robert
> _____
> my OTA channels?
> _____
> Yahoo! Groups Links
> Yahoo! Groups Links
It seems like VOOM needs a refresher in FCC regs. I can see how a rental
box can be turned off completely for non-payment, but how can they
legitimately think it's OK to turn off the OTA on a receiver that they no
longer own? I guess that until someone goes after them legally they will be
right....
Sent: Tuesday, February 01, 2005 9:09 AM
> Hi Again:
> receivers.
> service......
> receiving digital
> jnardone
> Yahoo! Groups Links
I read it as the OTA's are provided and the tuner at no extra charge. But
but tuner is part of the Voom package. You cancel and they have every right
to disable that feature. Yeah I think it sucks. As for the FCC reg below.
That won't apply to VOOM. The tuner was part of the service, you cancel
Voom and the receiver is canceled as well. No where does it read that the
tuner must still be accessible to the user if the service is canceled. As
long as you are a VOOM Subscriber the below would apply
~Eric
_____
Sent: Tuesday, February 01, 2005 9:47 PM
right....
> Hi Again:
> receivers.
> service......
> receiving digital
> jnardone
> Yahoo! Groups Links
_____
Yahoo! Groups Links
