I thought you had movement problems on the 1.2?
It's not windy right now, so no movement
Does this look correct? Can never remember if left and right are facing the dish or behind it
View attachment 136180 View attachment 136181 View attachment 136182 View attachment 136183
Instead of putting the side arm position and through-bolt where it is now (through the KU-band poly clamp), move the side arms and through-bolt down to the next set of holes on the center arm. This lower position also provides clearance for the C-band conical scalar.
I do not recommend the CK1S for mini BUD experimentation. The unit performs well on most full size dishes, but will provide poor performance on an undersized reflector. Combo feeds are a compromise and will likely provide reduced performance on both bands.
Whats your Q on CW like? I dont even get a whiff of CW no matter what i do on my Channel Master 1.2mSuccess! On 91W, getting The Word Network, CW Plus, Classic Arts, BYU TV, TCT, LightTV and a bunch of scrambled stuff
I played with the skew but still no luck. I will try again and see if any luck72%-90% yesterday afternoon
But I had to skew the LNB to get ARTS in HD to come in and lost the CW mux
Thats true. The beam is not very strong at my location but I will try to tweak the lnb at night. I dont know if its true but I have heard that the signal is comparatively stronger at nightMay also have to do with the signal footprint. Being close to the geographic center of the US, I may be able to receive a stronger signal
Limited time offer
