Receiver Connections | SatelliteGuys.US
apollobc
4
Boulder City, NV
:confused: Hello... New to DISH and expecting an install this week! I am uncertain as to how many dish connections are required to connect to the satellight. From what I can tell it takes 2-cables from the dish to the receiver? If I have 3-Receivers does that mean 6-cables are required from the dish? (1-duel and 2 single receivers). As a side note what is ment by "Agile Modulated Output"?
Thanks again for any enlightment on the subject!!
PS You guys must just hate these newbie questions... :)
Nope, Dish only needs one cable from the dish to the receiver, even for dual tuners. Three receivers three cables. I can't answer the AMO question.
About Receiver Connections
Thanks for the information guys....
I was concerned because the picture of the receiver shows 2 satellite connections??
Don't worry. The two tuner inputs you pictured take a thing called a "separator", via two stubby coaxes, both supplied with the receiver. A single coax comes down from the dish, and connects to the separator.
you'll get something similar to this
dish has always been great about this. after such a long time directv has begun to do a similar install. you'll be extremely happy with their hardware! by the way welcome to satguys :)
The agile modulator is a RF signal generator that provides both TV1 and TV2 in NTSC format via a single coaxial cable connection from the rear of the 622/722/722k.
You can choose the output channels for TV1 and TV2 to send to outlying TV sets so that they can be modulated into your OTA channels with minimal interference.
Can I still use 622 for OTA HD if unsubscribed?
Solid V Stranded wire
